cgmp Posted January 31, 2014 Posted January 31, 2014 Hey guys my speedo runs smoothly up to about 40mph then when I put my foot down or even just sit above 40 the needle shakes rather than moving smoothly up? It's not really anything that bothers me but would be good to fix if it was easy enough? Cheers guys! Quote
Bluebear Posted February 1, 2014 Posted February 1, 2014 (edited) Make sure the speedo cable is screwed in properly at the gearbox? I had a similar problem before after doing work on the engine, turned out I had only lightly screwed the cable back on so it wasn't even tight. Edited February 1, 2014 by Bluebear Quote
5T4R7ET N/A Posted February 1, 2014 Posted February 1, 2014 Also greasing the end of cable, would help. Gearbox side and the speedometer side if its dried up Quote
cgmp Posted February 1, 2014 Author Posted February 1, 2014 Make sure the speedo cable is screwed in properly at the gearbox? I had a similar problem before after doing work on the engine, turned out I had only lightly screwed the cable back on so it wasn't even tight. Also greasing the end of cable, would help. Gearbox side and the speedometer side if its dried up Thanks guys ill give them a shot! Quote
Liam_D Posted February 2, 2014 Posted February 2, 2014 Mines wobbly too? Maybe it's just because it moves so fast Would be nice to know a fix for this in all seriousness Quote
