Hey guys my speedo runs smoothly up to about 40mph then when I put my foot down or even just sit above 40 the needle shakes rather than moving smoothly up? It's not really anything that bothers me but would be good to fix if it was easy enough? Cheers guys!
Make sure the speedo cable is screwed in properly at the gearbox? I had a similar problem before after doing work on the engine, turned out I had only lightly screwed the cable back on so it wasn't even tight.
Edited by Bluebear
Also greasing the end of cable, would help. Gearbox side and the speedometer side if its dried up
Thanks guys ill give them a shot!:)
