Scottyboy Posted February 5, 2014 Posted February 5, 2014 http://s7.postimg.org/6pbagetnv/image.jpgDoes anyone know what this is found it in the glove box Quote
Scottyboy Posted February 5, 2014 Author Posted February 5, 2014 http://s8.postimg.org/kigw87efp/image.jpgPhoto of the wires Quote
Ollieh17 Posted February 5, 2014 Posted February 5, 2014 Fuel cut defender i believe? someone can confirm that Quote
Gainzy Posted February 5, 2014 Posted February 5, 2014 It's a Jam racing fuel cut defender stops the car from hitting fuel cut over a certain boost pressure Quote
Scottyboy Posted February 5, 2014 Author Posted February 5, 2014 I did think that by wanted to confirm cheers boys anyone got a wiring diagram for this bad boy? Quote
Scottyboy Posted February 5, 2014 Author Posted February 5, 2014 I'm also wiring in my safc2 today also I beleave certain fcd's don't work well with a safc true? Quote
Gainzy Posted February 5, 2014 Posted February 5, 2014 You should be able to control your fueling/air through that so you shouldn't need the fcd..http://www.toyotagtturbo.com/forums/showthread.php?9612-wiring-diagram-for-fcd Quote
Scottyboy Posted February 5, 2014 Author Posted February 5, 2014 Ok dude I'll give it a bash other people have had them wired via the map sensor I'm guessing that's the pressure sensor on the ecu an they have just taped in further up the harness? Quote
Scottyboy Posted February 5, 2014 Author Posted February 5, 2014 I'm not sure how it would control the air mate as no airflow metre? Quote
