JDMjunkie Posted February 7, 2014 Posted February 7, 2014 Way out of my depth i'm no electrician! so just wondered if there's anywhere I could take it to get it all re-wired because at the moment I'm just staring at exposed wires that should be in a block. Quote
TurboTobz Posted February 8, 2014 Posted February 8, 2014 Headunit wirings a good starting point for a beginner mate it helped me.understand bigger things when I were younger Quote
Jamie5414 Posted February 8, 2014 Posted February 8, 2014 (edited) What Starlet is it bud, ep91? I'm sure we can help with pictures etc... find you some diagrams or something ** Just seen your photo on facebook, You'll need another block with wires sticking out, then solder the wires on colour to colour. It's just a matter of getting the correct block for them wires and it'll be sorted Edited February 8, 2014 by Jamie5414 Quote
JDMjunkie Posted February 8, 2014 Author Posted February 8, 2014 Cheers lads, I just don't have the patience I'll rip it all out if I do it. Quote
Jay85 Posted February 10, 2014 Posted February 10, 2014 Just to add a lil tip, if you need to find the speaker wires n pair them up. Use a 5v battery (the kind you stick your tongue on) and connect a wire to each terminal, of you've got a pair you will hear a very slight pop. It's not enough to damage the speaker, but it has saved me hours in the past!! Quote
