tested the live on the end of the pump and theres no power, im trying to find the plug up the ignition end to see if theres any loose connections etc, ep82 by the way, but any help would be much apprecuated
They don't only when you turn it to the starter position to crank it over , turn the key to start it for like a second and then leave the key go and see if you can here it as they keep pumping when you let go
