mattyD Posted February 10, 2014 Share Posted February 10, 2014 Looking to get this glanza running and have come in to a slight problem. The engine is from a GT and the loom from a Glanza, on looking it appears there seems to be some difference between the connections to some sensors and alternator etc. Anyone have any ideas of the actual sensors that are different? At the moment I have the coolant temp sensor and alternator. Quote Link to post Share on other sites
Socks Posted February 10, 2014 Share Posted February 10, 2014 There the only ones.... As far as im aware... I believe the change was All GT and Pre-Facelift Glanza then changed on Facelift Glanza.... Fusebox is completely different and wiring loom going thru firewall in different arrangements! But the two coolant temp sensors and A/T are the only differences I think! Quote Link to post Share on other sites
Idrees Posted February 10, 2014 Share Posted February 10, 2014 The TPS may also be different if it's an early EP82 (which it sounds like it is due to the alternator plug difference). Quote Link to post Share on other sites
mattyD Posted February 10, 2014 Author Share Posted February 10, 2014 Sweet, thanks lads As said, all I have found is just the two mentioned so hopefully that is all The engine is from a mk2 GT, would this and the glanza use the same TPS? Quote Link to post Share on other sites
hookie663 Posted February 10, 2014 Share Posted February 10, 2014 Fitted gt engine to mine at summer ther wif glanza loom no probs only ting I did was change the thermoset house over from glanza engine to the gt engine? Had no problem wif altonatter lik or anything else I do know the inlet manifold gaskets r different and the inlet manifold to Quote Link to post Share on other sites
mechiel Posted August 10, 2015 Share Posted August 10, 2015 is the tps exactly the same on both GT and EP91? I'm using a GT engine now, but would like to put in the EP91 wiring. Do I need to change the TPS? Quote Link to post Share on other sites
