chigs123 Posted February 11, 2014 Posted February 11, 2014 As I've searched high and low for an ep91 4efte manual loom and not found a thing! I was wondering if there are alternative routes, I have the ecu and everything else... I was wondering if a auto loom would work but just obv not plug in the plugs the the auto side of things? :/ surely if the ecu is manual it will give the engine the necesary info to run? Any help would be much appreciated.Charlie. Quote
turbo Grant Posted February 11, 2014 Posted February 11, 2014 You could just wire in an engine loom intro your existing loom. That's what I done on my ep70 conversion Quote
chigs123 Posted February 11, 2014 Author Posted February 11, 2014 How would I go about that? The problem would be that I've just bought an ep91 3 plug ecu :/ Quote
turbo Grant Posted February 11, 2014 Posted February 11, 2014 GT ecu is the best to retro fit as it has 2 plugs. If you get a auto loom say you just rip out all the wiring to do with the engine a mate it to your old loom. Quote
chigs123 Posted February 11, 2014 Author Posted February 11, 2014 Could I not just get the ep91 auto loom so it fits my manual ecu then rip out everything to do with the auto box? Quote
Stu Posted February 11, 2014 Posted February 11, 2014 As long as you have a loom that plugs into your ecu you can make it work if its auto or not Quote
chigs123 Posted February 11, 2014 Author Posted February 11, 2014 Well I was going to buy one off ebay but obviously don't want to shell out like 100 quid if it won't work :/ Quote
