nikhilkamdar12 Posted February 19, 2014 Posted February 19, 2014 (edited) Re-shelling my V into a 96 shell from my damaged 99 shell and there is one hole in the 96 spec that ain't in my 99. A picture below to show the hole that I need a bung for?? It's the hole that is dead in the middle of the bulk head. If you could supply a bung would be great ... CheersNik. Edited February 19, 2014 by nikhilkamdar12 Quote
Idrees Posted February 19, 2014 Posted February 19, 2014 The wiring loom usually feeds through there so I'm not sure there is a bung for it. I'll check tomorrow anyway. Quote
Aamir Posted February 19, 2014 Posted February 19, 2014 (edited) Hi Idrees, I'm after one as well, could you drop me a PM if you can supply them. Cheers bud Edited February 19, 2014 by Aamir Quote
nikhilkamdar12 Posted February 19, 2014 Author Posted February 19, 2014 Understand it's a hole for the loom but I have the 99 loom this hole is redundant so no need. But if you have any that will fit will take one CheersNik. Quote
JDMfreak Posted February 19, 2014 Posted February 19, 2014 96 shell have that for the wiring 98 go through the bung just at the side of the shock mount you could cut two circles slightly bigger then the hole out of thin sheet steel put one on the inside and one on the out side drill a hole through both and put a nut and bolt through it tighten it up and hole is blocked Quote
nikhilkamdar12 Posted February 19, 2014 Author Posted February 19, 2014 Could do but want to keep it all looking neat and tidy and a simple rubber bung will do the job and watertight Quote
mccartney11 Posted February 19, 2014 Posted February 19, 2014 measure the size and youd pick one up on ebay or in halfords im sure.. Quote
