Bleed Nipple on rear drum (Thread size?)
Just got around to fitting my braided lines front and back, the bleed nipple on the passenger rear drum has came clean off with the thread still inserted...
Heated it up a little before and let it cool then tried to crack it off with a spanner to bleed them, heard it crack off the tightness after a few hits against the spanner with my hand, then another hit it came clean off...
What is the thread size on the drum, anyone know? Got drill bits and a tap, and a spare bleed nipple in the garage so just need to know what to tap it to?
Thanks,
Jamie
