What have you already done tho? Inlet mani/tb is one of the last thing that needs to be changed on a starlet. Have you done everything else thats going to give you better gains first?
adamb that's perfect I was planning on using a 70mm one
The larger you go the less bottom end power you get due to gas velocity, but obviously you have to make a compromise if your going for power. 70mm is good for 500bhp so you can sacrifice a bit of diameter if need be.
Rob sr:
The car is running a fully forged 5e with a gtx 2863r turbo and a full standalone megasquirt ecu and I have a wepr intake manifold
Edited by grum-glanza
not really as far as I know there is a three angle cut on the valves does headwork make much of a difference?
Depends what headwork your after and how deep your pockets are lol. Most of the time pissing about with the cylinder head makes it worse than what the stock item was.
