kaiep91 Posted February 27, 2014 Posted February 27, 2014 Hi I am looking to take my turbo to a garage to get the penny welded I am going to be running a td04 external wastegate setup?Is it correct to tell them just to weld the penny shut or is there anything else that needs to be done? Quote
ro55ifumi Posted February 27, 2014 Posted February 27, 2014 Drop Dean a line at RW Developments, he can weld it up for you, at one point he did create a bracket that holds it shut to John Quote
starletburkie Posted February 27, 2014 Posted February 27, 2014 I blocked off the hole it mine with a piece of 25mil bar and welded it around! Least it will be 100% sealed that way IMO the puny shit isn't a 100% seal Quote
Ollieh17 Posted February 27, 2014 Posted February 27, 2014 I put a bolt through the actuator bracket and welded that to the housing. Can just chop that off then and use the turbo with a normal actuator Quote
