russ78 Posted March 4, 2014 Posted March 4, 2014 as above need to know size and length of stock wheel hub studs Quote
jayc-glanza17 Posted March 4, 2014 Posted March 4, 2014 stock studs are m10x1.5 I run m12x1.5 because of my wms brake kit and wheel spacer. russ I may have some m12s left over if you need any?? Quote
morgey Posted March 4, 2014 Posted March 4, 2014 Stock studs are M12 x 1.5Longer ones can be brought from eBay or toyota if need be. 63mm is common extended size iirc Quote
