Can anyone tell me how I disconnect the middle fuel line.
I soaked the thread in wd40 beforehand, but the bolt will not budge. I was being mega careful not to bend the fuel line either.
Thanks
$T2eC16NHJG!FFmyb42PKBSN67FBP,Q~~60_35.J
One of these on the smaller nut then a large spanner on the other. I remember mine being pretty tight and it had been undone in the past. Good luck and be careful not to round off the smaller nut, easy to do without the correct tools.
Edited by TimD
Thanks lads. Had a nightmare today trying to get it off with my normal spanners. How much are the above spanners?
Like you said RBZ, the pipe bent slightly while trying to release it, so called it a day.
Thanks Tim.
Just to double check. I need to hold the top nut in place with the above spanner, then try and unscrew the bottom bigger nut?
