Djaniero Posted March 16, 2014 Share Posted March 16, 2014 Can anyone tell me how I disconnect the middle fuel line. I soaked the thread in wd40 beforehand, but the bolt will not budge. I was being mega careful not to bend the fuel line either. Thanks Quote Link to post Share on other sites
TimD Posted March 16, 2014 Share Posted March 16, 2014 (edited) One of these on the smaller nut then a large spanner on the other. I remember mine being pretty tight and it had been undone in the past. Good luck and be careful not to round off the smaller nut, easy to do without the correct tools. Edited March 16, 2014 by TimD Quote Link to post Share on other sites
Beastmode panda Posted March 16, 2014 Share Posted March 16, 2014 As above. BUT be careful because the pipes are SO brittle and can/will twist and/or snap if you aren't careful mate. Quote Link to post Share on other sites
Djaniero Posted March 16, 2014 Author Share Posted March 16, 2014 Thanks lads. Had a nightmare today trying to get it off with my normal spanners. How much are the above spanners? Like you said RBZ, the pipe bent slightly while trying to release it, so called it a day. Quote Link to post Share on other sites
TimD Posted March 16, 2014 Share Posted March 16, 2014 Mine came from Machine Mart. http://www.machinemart.co.uk/shop/product/details/pro72-3-pce-af-flare-nut-wrench-set Quote Link to post Share on other sites
Djaniero Posted March 17, 2014 Author Share Posted March 17, 2014 Thanks Tim. Just to double check. I need to hold the top nut in place with the above spanner, then try and unscrew the bottom bigger nut? Quote Link to post Share on other sites
TimD Posted March 17, 2014 Share Posted March 17, 2014 From memory that's how did it, I didn't have any problems with the pipe bending on mine. Quote Link to post Share on other sites
