Meister r front coilover noise
Front left coilover is making a springy knocking sound when going fast round a roundabout, sounds like it's coming from the spring or topmount. Tried tightening the topmount nut, however it just keeps spinning with the rest of the shaft thing. What to do?????
I wanted to try tightening the top nut on my Meister's, but the top adjuster knob didn't want to come off. It was kind of spring loaded and would snap back down if I tried pulling it off. Didn't want to pull with too much force though, maybe I was just being a wimp. Is there a trick to removing it? I don't think it's the same as the D2's
You need a spanner to loosen it, its the red part that looks like a nut, not the circular knob that you turn with your fingers.
Hope that makes sense.
Edwin
  • 1 year later...
Kinda bringing this back from the dead so I apologise, but my question is directly related.
To tighten the top nut do I need to remove the adjuster first by loosening the red "nut"? Or can I just grip that with a spanner whilst I tighten the big main nut beneath it?
Take the adjuster off first with a 10mm spanner. Then it reveals a hex/allen socket for your hex/allen key.
Edwin
