I ran a coil pack. I've seen the sane ones run 550bhp on vauxhalls. I have the blanking bung and mounting plate Yeah. In the pic you can see the bung and the metal plate behind the coil pack.
This is fitted with an ep82 loom adapter.
i made the ht leads my self from magnecore starlet leads and i changed the ends to fit the coilpack i should have those too which i could include. the coilpack is in the pic at the top with the bung.
I got a stock ep82 ecu to cut the connector out of it to use to make this loom. I think you would need to do the same with an ep91 and change the plug then you would have an adapter loom.
still got the INLET? sorry if i missed it
Yeah still got the inlet which I'm suprised as it's a nice setup. Better than some of the aftermarket ones that go around.
  • 3 weeks later...
  • 2 weeks later...
  • 1 month later...
