If you pull one of the pipes off the heater matrix and also one off the thermostat housing and fire a hose pipe in it you can force the old coolant out and flush it with clean water. Then start putting coolant in when all the old shit it out.
The pipes go through the bulkhead to the heater matrix, near the throttle body area.
