The calipers will fit, but you need the carrier too. You'll also need the bigger discs and pretty sure new pads too - the Glanza pads are a different shape I'm 99% sure.
We can help with both if you need them, on the shelf....
You can use n/a calipers but you need to use the caliper carriers from a Glanza. Then you would need Glanza 256mm discs and n/a pads.
Or get Glanza or gt calipers and there'll probably be more options for pads
