Tommyk Posted March 26, 2014 Posted March 26, 2014 Hi people I took cams out and didn't know one has to have a bolt to keep tension and now top end sounds abit rattly. How do I cure this? Quote
maddox710 Posted March 26, 2014 Posted March 26, 2014 They have to be torqued back down in sequence Quote
Tommyk Posted March 26, 2014 Author Posted March 26, 2014 What you mean mate just tourque cam holder back down and Shud be fine? Cam holders* Quote
maddox710 Posted March 26, 2014 Posted March 26, 2014 Yeah there is a guide somewhere on there. It has to be tightened in a sequence too Quote
Tommyk Posted March 26, 2014 Author Posted March 26, 2014 Ok mate. Il have to find out don't like the sound of it haha Quote
5e colin Posted March 27, 2014 Posted March 27, 2014 you nead to tension the intake cam cog then just reinstall it the sound will be gone and 9nm torque on the caps Quote
GP82 Posted March 27, 2014 Posted March 27, 2014 Yup there is the service bolt that should have been installed so the sub gear is aligned with the adjacent gear on the camshaft sprocket. Your gonna need to find a way so these gears on the sprocket align to let you get the service bolt through. After you have confirmed the valve clearence's, on the final assembly, you install the camshafts with the service bolt still there. After you have torqued the cam caps, you just take the service bolt off to get the gears on camshaft tensioned. Good luck. Quote
Tommyk Posted April 13, 2014 Author Posted April 13, 2014 Hi guys had engine stripped again don't ask why haha and I put the bolt in this time and sounds like a diesel again so I have just took cam out with out putting the bolt in and 're tensioned it and put the bolt in then refitted cam and is still the same any ideas ? Quote
Sefton-EP91 Posted April 19, 2014 Posted April 19, 2014 (edited) Read the second from last comment and follow instructions mate I will be doing the same 2moz hope this helps.http://www.toyotagtturbo.com/forums/showthread.php?28144-lining-up-cams Edited April 19, 2014 by Sefton-EP91 Quote
