mine where already off when i bought the car bought im not too sure. But under the strips are white clips that hold them i think they are just stuck to the car with adehisive stuff. As for taking the strips off i dunno if you have to slide them off or pull them off.
Im sure some of the other boys will be able to help you better
Eventually if for some reason ya cant take them off get them colour coded like Nanglebadger did (Phil)
i took mine off my 96 sportif and all it is held on with is sticky shit. i just lifted mine from one corner then slowly peeled it all off and used some tar remover to get the rest off. so im guessing yours will be the same.
Yeah, they advised minuszro to use a hairdryer to heat them, make them easier to get off i guess, and then white spirits or meths or petrol should take care of the glue. Or if your car has been damaged by some wee assclowns with a brick like mine was colour code them, it also means that if some GOAT opens their door into your car hopefully the rubbin strip will be what is hit and its cheaper to mask that off nd have it sprayed then a whole door.
Let us know how u get on, even a few pics, before and after ones!!!! :D ;)
Phil.
thanks guys! you've been really helpful! sounds like a job for a dry day! i shall keep you all upto date :-)
not sure what ill do yet because i got little TRD stickers on my strips that reflect when light hits them haha!
