rockrees Posted March 29, 2014 Posted March 29, 2014 (edited) Hey everyone, recently had my head gasket done literally a few months ago so it can't be that, but I've noticed that once I've driven my car hard and pop open the bonnet for a daily inspection there is always coolant on the underneath of the bonnet and in the engine bay, looks like it's coming from the expansion tank to me. Maybe a seized thermostat? The temperature sits perfectly and cools as it should though. Checked my oil yesterday as well and noticed I was almost at the low/minimum mark. (no oil leaks, all the turbos connections seem fine)Does smell a tiny bit oily in the exhaust gasses though, so worst case piston rings? (random guess)Any ideas? Thinking worse case scenario at the moment, probably something simple. Edited March 29, 2014 by rockrees Quote
Mad Mike EP82 Posted March 29, 2014 Posted March 29, 2014 Are you still on standard rad and cap? Could be weak rad cap or coolant leak somewhere. Or worst case headgasket gone again or cracked head/block Quote
rockrees Posted March 29, 2014 Author Posted March 29, 2014 Yeah it's a standard radiator and cap, worth upgrading then I guess?No no no, please don't say that haha :'(Thanks for the help. Quote
richardc9052 Posted March 30, 2014 Posted March 30, 2014 It's only doing that because it's boiling over which is because it's not reaching the required pressure to raise the boiling point to the level needed.Possible causes are;Weak/faulty rad capCoolant leak via Rad, water pump, piping, heater matrix Head cracked Head gasket goneWater pump failure Quote
5e colin Posted March 30, 2014 Posted March 30, 2014 richard you forgotten to ad cracked block to Quote
rockrees Posted March 30, 2014 Author Posted March 30, 2014 (edited) Fitted new pipes a few days ago and literally spend hours today checking for any leaks. Went on a long drive last night and since the water level has dropped a bit, (less pressure) no more coolant is trying to escape. I'll start with the radiator cap first, then move on from there. (Just ordered the OE Spec, high pressure one from ID_WORKZ)However, looks to me like my oil is still being eaten up, nom nom nom. Might get a pressure test done to be on the safe side. Thanks a lot everyone Edited March 30, 2014 by rockrees Quote
rockrees Posted April 6, 2014 Author Posted April 6, 2014 Just an update, turns out it was my fault, you can only fill the expansion tank to minimum otherwise the water overflows whereas I was filling it just under max. The oil will go down as well because it's my daily and I do a lot of short journeys, does use a lot though. Quote
