what the hell is one of those thingys on top of peoples rocker cover. mines got a pipe on it. some people have a small air filter on it. what does this do and what is the difference having that to the pipe.
Its a breather filter, the engine needs to breathe so requires some opening to vent gases.
The filter just keeps it a bit tidier as any oil which is blown out will soak into the filter instead of straight out the end of the pipe.
The best thing to have as an oil catch can to keep things properly tidy.
Pressure builds in the engine crankcase due to vapor from
the hot engine oil and from exhaust gases that escape
past the piston rings. A crankcase breather system is used
to release this pressure. If the breather system becomes
blocked, the crankcase pressure builds internally. As
the pressure increases, the oil is pushed through the
area offering the least resistance, such as the dipstick or
a seal. Crankcase breather filters are employed to ensure
the crankcase does not become blocked with foreign
materials as pressurized gases escape.
Nice use of copy and paste there. :):D
why write it when somebody has done it for me lol! :ph34r:
Filters on the rocker cover just get soaked in oil and then ends up spraying it over the cover in the end.
Invest in a catch can as starbos do enjoy breathing heavy.
