white-gt Posted April 11, 2014 Posted April 11, 2014 Hi guys, i seem to have an issue started where one cylinder ht lead is comming off the spark plug, i can then push it back on and it could literally pop off and land at the manifold still sparking.. am i right in saying it could be the spark plug not all the way down or is it a case of the seals on the cam cover..? never had this issue before so im not too sure.. Quote
mikey4410 Posted April 11, 2014 Posted April 11, 2014 surely the only way that can happen is because of pressure coming from spark plug hole. Quote
white-gt Posted April 11, 2014 Author Posted April 11, 2014 so that would be the 4 rubber rings the spark plug tube seals or something?http://www.ebay.co.uk/itm/Toyota-Starlet-GT-Turbo-Glanza-V-Rocker-Cover-Cam-Cover-Gasket-Set-OE-Quality-/131004764336?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e807e10b0 Quote
Sefton-EP91 Posted April 11, 2014 Posted April 11, 2014 Just check the sprak plug is tight mate and also might be worth changing the spark plug seals aswell Quote
white-gt Posted April 11, 2014 Author Posted April 11, 2014 i'll check its tight when i get home, might try swap the plugs around.. ive ordered that kit ive posted above anyway so i'll let you know how i get on! Quote
5e colin Posted April 11, 2014 Posted April 11, 2014 it will be plug loose backpressure wont be able to blow out the pluglead also make sure you fit the sparkplug seals the right way up !!!!!!!!!!!!!!!!!!!!!!! Quote
white-gt Posted April 12, 2014 Author Posted April 12, 2014 Sorted ! Swapped plugs about and tightened right up, seems perfect ! I just ordered that kit too lolThanks guys Quote
