starlet86 Posted November 25, 2007 Posted November 25, 2007 Rite, In the last week or so i have noticed that (sometimes) my car doesn't seem to be pulling properly.The boost gauge says its boosting at a steady 0.8bar but it doesnt seem to be pulling like it should. 1 day it will be pulling fine and if i plant it in second it will spin in the dry, then other days it wont even spin in the wet in 2nd!! It feels as if it goes a little then holds back then pulls n its kinda gently pulling then holding off! Only mods i have are:MBCFMICForge BOVRunning 0.8barAny help would be appreciated guys!! Thanks Quote
paul w Posted November 25, 2007 Posted November 25, 2007 Rite, In the last week or so i have noticed that (sometimes) my car doesn't seem to be pulling properly.The boost gauge says its boosting at a steady 0.8bar but it doesnt seem to be pulling like it should. 1 day it will be pulling fine and if i plant it in second it will spin in the dry, then other days it wont even spin in the wet in 2nd!! It feels as if it goes a little then holds back then pulls n its kinda gently pulling then holding off! Only mods i have are:MBCFMICForge BOVRunning 0.8barAny help would be appreciated guys!! Thanks Check plugs and leads first.May be a boost leak but i'd bet it's plugs. Quote
starlet86 Posted November 25, 2007 Author Posted November 25, 2007 I've checked all the pipes and they seem to be fine so hopefully its as simple as plugs, will do them 2morow and see if it works! Thanks Quote
Ramsey Posted November 25, 2007 Posted November 25, 2007 I've checked all the pipes and they seem to be fine so hopefully its as simple as plugs, will do them 2morow and see if it works! Thanksmine does the exact same! let me no if plugs sorts it mate Quote
Rob Posted November 26, 2007 Posted November 26, 2007 hi i am a new member and i am finding that my EP82 is almost having the same problem but its not holding boost when it hits 0.9 bar the boost starts to drop to 0.5 bar so if you get yours sorted pls let me no as i could be looking at the same problemthanks Quote
Sparky Posted November 26, 2007 Posted November 26, 2007 Get a HKS actuator The spring is soft in the standard actuator so it leaks boost at high rpm Quote
starlet86 Posted November 26, 2007 Author Posted November 26, 2007 Been given a busy week at work so going to do it on thursday morning and give it a try and let u know. As for the HKS actuator thing it seems to be doing it through the whole rev range but might invest in one neway!! Saying that it seemed fine today because i have been driving around alot as i fitted my HKS SSQV (sounds amazing!!) but i know it will do it again so going to try what i can and see what works!!! Quote
carter Posted January 12, 2008 Posted January 12, 2008 hi there can any one help? when i go over 5000rpm the boost starts to drop off from 0.8 to 0.5 you can watch it go down. can any one help me. pm plzModsHKS actuatorHKS SSQS (blow off value)HKS power flow indution kitmagacore lead 8.0mmNGK sparks grade 7Auto bann 88 front mount intercoolerStandard CT9 (A) Turbo waste gate portedOil catch tankgreedy oil filter oil change 15 dec07. Quote
