Rob Posted November 26, 2007 Share Posted November 26, 2007 hey i am having a real prob with keeping high boost.when mine hits 0.9 bar it starts to drop to 0.5 bar.has any one had this before if so pls tell me what the prob was i need all the help i can get lol pls get back to me asap Quote Link to post Share on other sites
montanajr Posted November 26, 2007 Share Posted November 26, 2007 Have you ever taken the EFI pipe off of the turbo? If so, sometimes the rubber insert can get folded over, and restricts air intake so at higher revs boost drops off. I used to have this problem, would hold 10psi to say 4500 revs then drop to 4. Took the pipe off, and the rubber insert was completely bent over. Fixed it, and holds 10psi perfectly now. Failing that, check for any leaks anywhere. Or its just your ct9 is running out of power in the higher rev range. Quote Link to post Share on other sites
StarletRick Posted November 26, 2007 Share Posted November 26, 2007 have you recently upgraded your actuator? if not, ill bet you money thats the issue. if you have replaced it with the hks model, check the tension on the spring, if it isnt wound on properly it will leak some pressure. Quote Link to post Share on other sites
Glanza_Ragger Posted November 26, 2007 Share Posted November 26, 2007 StarletRick said: have you recently upgraded your actuator? if not, ill bet you money thats the issue. if you have replaced it with the hks model, check the tension on the spring, if it isnt wound on properly it will leak some pressure.As Rick stated, i bet youre running the stock actuator.There absolute p!ss holding pressure.If you have an uprated item, check for leaks in the basic places, turbo lines, intercooler etc. Quote Link to post Share on other sites
Rob Posted November 26, 2007 Author Share Posted November 26, 2007 as far as i no its not been changed but i am looking in to getting the HKS one as i am wanting to do a few modds under the bonnet.i am peed off about the boost as i got done by a 106 gti lol Quote Link to post Share on other sites
Rob Posted November 26, 2007 Author Share Posted November 26, 2007 thats what every one is saying so i think i will be getting a new one. just hope thats it Quote Link to post Share on other sites
carter Posted January 22, 2008 Share Posted January 22, 2008 hi there can any one help? when i go over 5000rpm the boost starts to drop off from 0.8 to 0.5 you can watch it go down. can any one help me. pm plzModsHKS actuatorHKS SSQS (blow off value)HKS power flow indution kitmagacore lead 8.0mmNGK sparks grade 7Auto bann 88 front mount intercoolerStandard CT9 (A) Turbo waste gate portedOil catch tankgreedy oil filter oil change 15 dec07. Quote Link to post Share on other sites
Glanza_Ragger Posted January 30, 2008 Share Posted January 30, 2008 carter said: hi there can any one help? when i go over 5000rpm the boost starts to drop off from 0.8 to 0.5 you can watch it go down. can any one help me. pm plzModsHKS actuatorHKS SSQS (blow off value)HKS power flow indution kitmagacore lead 8.0mmNGK sparks grade 7Auto bann 88 front mount intercoolerStandard CT9 (A) Turbo waste gate portedOil catch tankgreedy oil filter oil change 15 dec07.As rick stated, youre actuator arm might not be adjusted well, OR the hks actuators spring has died over time.How old is the hks actuator ? Quote Link to post Share on other sites
montanajr Posted January 31, 2008 Share Posted January 31, 2008 carter said: hi there can any one help? when i go over 5000rpm the boost starts to drop off from 0.8 to 0.5 you can watch it go down. can any one help me. pm plzModsHKS actuatorHKS SSQS (blow off value)HKS power flow indution kitmagacore lead 8.0mmNGK sparks grade 7Auto bann 88 front mount intercoolerStandard CT9 (A) Turbo waste gate portedOil catch tankgreedy oil filter oil change 15 dec07.Read what I suggested up. A few of us over at TGTT have had this problem, and its an easy fix that makes a lot of difference. Quote Link to post Share on other sites
carter Posted February 1, 2008 Share Posted February 1, 2008 i had the thing act-u for about 3 months. montanajr said: Read what I suggested up. A few of us over at TGTT have had this problem, and its an easy fix that makes a lot of difference. Quote Link to post Share on other sites
