EP91crazy Posted April 16, 2014 Share Posted April 16, 2014 Basically be driving and the car will always pull to the left sometimes a little sometime not at all but other times really badly... then under braking it seems really twitchy and I've got to control it under braking otherwise it'll go on its on demise....? Done tracking aint that.... noticed one wheel the nsf has no spigot ring but the other front does... ? Amy ideas Quote Link to post Share on other sites
EP91crazy Posted April 18, 2014 Author Share Posted April 18, 2014 Anyone seems to be getting worse... front brakes are fine and free Quote Link to post Share on other sites
StarletSr? Posted April 18, 2014 Share Posted April 18, 2014 Are the discs warped? Quote Link to post Share on other sites
morgey Posted April 18, 2014 Share Posted April 18, 2014 Tyre pressures. Rear brakesCamber on the wheels Quote Link to post Share on other sites
EP91crazy Posted April 18, 2014 Author Share Posted April 18, 2014 Pressures are fine. Camber is slightly more as lowered... rear brakes possible as it's had a recon caliper so maybe at fault cheers Quote Link to post Share on other sites
morgey Posted April 18, 2014 Share Posted April 18, 2014 try checking the camber (decent alignment center can do this), one side could be more than the other as theres a slight bit of movement in the shock mountings. also check that the handbrake on and isn't pulling slightly on one caliper Quote Link to post Share on other sites
EP91crazy Posted April 18, 2014 Author Share Posted April 18, 2014 Il Check what the camber results were on 4 wheel alignment. .. and check rear brakes. .. front discs should be fine... think maybe the rears... what about wishbone bushes??? Quote Link to post Share on other sites
dangeestarlet Posted April 18, 2014 Share Posted April 18, 2014 Bleed the brakes, mine used to do that when I changed calipers, bleed all of them as one or two of them ain't working by the looks causing it to go to one side when braking Quote Link to post Share on other sites
EP91crazy Posted April 18, 2014 Author Share Posted April 18, 2014 Ok cheers il give it a entire flush through and check rears Quote Link to post Share on other sites
