Mcinnes Posted April 21, 2014 Posted April 21, 2014 I've currently got a toyota starlet gt ep 82.I've currently got stainless steel exhaust and manifold system, competition race clutch, grooved rear discs, fount mount inter cooler, chrome hard pipes, sard adjustable fuel pressure regulator, lowering springs and shocks and an air filter.My next idea is a td04 turbo and uprated injectors, I've been told I'll probably need a fcd. Would I need a re map straight away I could I put it off for a while ? Or is there something better I could get for same price ?? Quote
Starbuck Posted April 21, 2014 Posted April 21, 2014 Get an emanage blue. That'll be your best bet. To make sure it's all fueling correctly and a uprated fuel pump. Quote
Mcinnes Posted April 21, 2014 Author Posted April 21, 2014 I've got the uprated fuel pump missed that out my bad also would I need high lifting cams as we'll so more air can get in to balance out fuel to weight ratio ?? Quote
ryan lang Posted April 21, 2014 Posted April 21, 2014 id go with some management first dude. cams arent really needed on td04 to be fair also go with some coilovers over lowering springs because springs are crap Quote
Mcinnes Posted April 21, 2014 Author Posted April 21, 2014 Yer I'm gonna order some from nengun straight from japan hand built , and what management would you suggest ? Quote
ryan lang Posted April 21, 2014 Posted April 21, 2014 urm greddy emanage ultimate id go for, but the emanage blue will be more than capable Quote
DevonGT Posted April 21, 2014 Posted April 21, 2014 Yer I'm gonna order some from nengun straight from japan hand built , and what management would you suggest ? Good coilovers can be got from the traders on here, for a lot less then getting them from Japan. Quote
Ollieh17 Posted April 21, 2014 Posted April 21, 2014 Theres a set of coilovers on evay for £265 or best offer just need to be unseized Quote
jayc-glanza17 Posted April 21, 2014 Posted April 21, 2014 where bouts in Essex you from matey?? feel free to look at my build thread to assist you.. personally get a Emanage and get it mapped and then concentrate on handling.. a rear anti roll bar is a mod that makes a great difference.. after that look at suspension, also don't forget brakes too.. Quote
Mcinnes Posted April 22, 2014 Author Posted April 22, 2014 I'm from Thurrock area but not there much because of the army and in afghan at the mo, but will when I'm back and okay guys cheers for all the advise Quote
