Rolla intake and exhaust manifold
your probably looking at around 60bhp for the intake and 30bhp for the exhaust, yeah they bolt straight on, but you might need a bit of selotape to hold them on, as selotape is stronger than nuts/bolts.
While your at it, get some viper stripes, they give you a good 10bhp.... per stripe!!!
Swap the bits over like in this photo, and just un-bolt your old manifold from the engine and throttle body, and then bolt on the corolla mani back onto the engine and TB.
If you can get the Throttle Body to go with the corolla manifold that would be a bonus, so you don't need to make any modification to the throttle cable.
Exhaust system is just bolt off and bolt on, get some new exhaust rubbers whilst your at it :)
Cut the corolla mani on the 2-1 so you have a short single pipe from the Y piece, then cut the pipe on your exhaust to match. tack, remove fully weld and replace :) Or do the same but add flanges to make it removable but the 4-2-1 corolla mani splits at the 4-2/2-1 part anyway
