Ollieh17 Posted April 24, 2014 Posted April 24, 2014 Not sure if this will fit with a stock rad? Any ideas? Quote
H_D Posted April 25, 2014 Posted April 25, 2014 looks like it is stock rad friendly as the wastegate flange is normally one the front of the manifold when using a civic rad.Your wastegate port is mounted to the side so should be ok with stock rad. Quote
