Fitted my new radiator this morning and everything went well. Bled it to get rid of air etc.
Car runs fine but temp gauge is now not doing anything at all.
Anyone able to shed some light on what could be up?
Check the sensors on the thermostat housing, just under the dizzy, the one for the temp gauge is on there.
Canny mind which one it is but because GTs and 96 / 98 spec V are different iirc.
Yeah I checked that and of course wire had snapped off so reconnected it and letting it heat up as we speak so will go out for a spin and make sure everything is ok
