Im after a spring for lower boost on a vband tial 38mm wastegate, comes with a 1bar spring. Googled it and noticed theres 'big' and 'small' springs? Do i need both of these to run under 0.8bar?
You will have to compare the springs once you have them apart, theres 10000000 of cheep waste gates out there it would be hard to tell with out seeing the springs together, but it should work as long as there similar in size. It can be shorter tho as that will lower the boost as long as is not too short or you wont get any boost lol
