burgess18 Posted May 3, 2014 Share Posted May 3, 2014 Quick question guys will a ep82 engine fit in my glanza.and everything else bolt on etc?? Quote Link to post Share on other sites
fremyjay Posted May 3, 2014 Share Posted May 3, 2014 Same engine bud so should do, cant see a reason why it wouldnt Quote Link to post Share on other sites
burgess18 Posted May 3, 2014 Author Share Posted May 3, 2014 Thats what I thought just wounded as all my.ecu turbo kit etc I dont want to have to change, but my conrod popped through my.block the other night so need an engine Quote Link to post Share on other sites
fremyjay Posted May 3, 2014 Share Posted May 3, 2014 Ecu is fine unless your changing the loom so thats not an issue, turbo kit will fit no problem as same engine, im just unsure on some of the auxillaries, but if your just buying a bare engine that wont matter Quote Link to post Share on other sites
richardc9052 Posted May 3, 2014 Share Posted May 3, 2014 It all fits.. Just make sure if your using your inlet mani that the head isn't the one with the water Chanel and the inlet doesn't have the extra material to block it. Try to get the inlet mani with it basically just to be sure It all fits.. Just make sure if your using your inlet mani that the head isn't the one with the water Chanel and the inlet doesn't have the extra material to block it. Try to get the inlet mani with it basically just to be sure Quote Link to post Share on other sites
Tarzan Posted May 4, 2014 Share Posted May 4, 2014 Put an ep82 engine into my glanza and it all works fine. Didnt know about the water chanel, as said above, and im waiting on an inlet and gasket. Quote Link to post Share on other sites
Adam M Posted September 11, 2014 Share Posted September 11, 2014 Just put a ep82 in my glanza and all fits/works just the two sensors under dizzy cap need swapping to fit your plugs on ep91 loom Quote Link to post Share on other sites
