Neo95 Posted May 5, 2014 Posted May 5, 2014 Yee, Like the title whats the best donor car to get a TD04 turbo from. I heard somewhere that the scooby ones spool up quicker but?? Thanks Neil. Quote
5e colin Posted May 5, 2014 Posted May 5, 2014 subu is widely available and most kits are made for subu turbo anyways spool depends on wich 1 ya get Quote
Neo95 Posted May 5, 2014 Author Posted May 5, 2014 subu is widely available and most kits are made for subu turbo anyways spool depends on wich 1 ya get Whats the better to get? Quote
gorganl2000 Posted May 5, 2014 Posted May 5, 2014 Subaru seems a popular choice with a lot of kits from various makers available as well as in the classified section Mitsubishi also have a few variants, but maybe some custom work needed to use those it's not really a choice of which is better...it's more what you want from your caralways build your car to make yourself happy Quote
Cushion Posted May 5, 2014 Posted May 5, 2014 TD04L normally mate as its got a smaller compressor housing Quote
Fozzie Posted May 5, 2014 Posted May 5, 2014 Make sure it has the triangular 3 bolt flange and not the rectangular 4 bolt one, as all Starlet manifolds are designed to fit the 3 bolt one. Quote
Neo95 Posted May 5, 2014 Author Posted May 5, 2014 Make sure it has the triangular 3 bolt flange and not the rectangular 4 bolt one, as all Starlet manifolds are designed to fit the 3 bolt one. TD04L normally mate as its got a smaller compressor housing Subaru seems a popular choice with a lot of kits from various makers available as well as in the classified section Mitsubishi also have a few variants, but maybe some custom work needed to use those it's not really a choice of which is better...it's more what you want from your car always build your car to make yourself happy Thanks a lot for all your help!! Quote
