Jamie5414 Posted May 6, 2014 Posted May 6, 2014 Can any of you lads help me out, I'm looking to get this EMB but does it fit a EP91? http://www.ukstarletowners.com/topic/80714-greddy-e-manage-blue/ Cheers Quote
5e colin Posted May 6, 2014 Posted May 6, 2014 you can yes you will nead to wire it up anyways there is no mention off a jumperloom with it so makes no diference Quote
Jamie5414 Posted May 6, 2014 Author Posted May 6, 2014 (edited) I was hoping to get a extension harness so I didn't have to cut/solder etc ep91 harness ep82 harness it doesn't look like the ep91 plugs would fit into the EMB as there's 3 ends on the ep91 harness? and only 2 plugs on the EMB? Edited May 6, 2014 by Jamie5414 Quote
Ollieh17 Posted May 6, 2014 Posted May 6, 2014 Dont the three white plugs go into the ep91 ecu? Quote
Jamie5414 Posted May 6, 2014 Author Posted May 6, 2014 I thought the plugs from the ecu go into the black part of the harness, then the white part of the harness goes into the EMB Quote
5e colin Posted May 6, 2014 Posted May 6, 2014 I was hoping to get a extension harness so I didn't have to cut/solder etc ep91 harness ep82 harness it doesn't look like the ep91 plugs would fit into the EMB as there's 3 ends on the ep91 harness? and only 2 plugs on the EMB? you see them plugs dont plug in the emb the jumper just plugs in between the oem loom and ecu (extending it ) then the wires coming from the smurf get soldered to the jumper ep91 harnes jumper can be used in both ep91 as ep82 :) Quote
Jamie5414 Posted May 6, 2014 Author Posted May 6, 2014 Ahhh right, I see where your coming from now, it all makes sense haha Never touched the wiring side of things in any car so this is a bit new to me, after looking at a few images on google about the EMB on a starlet a lot of them are really straight forward just follow the diagram and splice the wires in where it tells you Thanks Quote
