Starlet Wayne Posted May 16, 2014 Posted May 16, 2014 does any one know if they are a staright fit, will they swap straight over or will it have to be modified? Pm me Quote
morgey Posted May 16, 2014 Posted May 16, 2014 You will have to loose your reverse light or get a Glanza boot surround and wire that in. Other wise it's unclip the old and clip in the new.Being 98 spec are you getting the whole light housing and not just the lense yeah? Quote
Starlet Wayne Posted May 16, 2014 Author Posted May 16, 2014 oh dam didnt want to change boot. the whole lighting housing Quote
Jamie5414 Posted May 16, 2014 Posted May 16, 2014 You dont need a reverse light, take the bulb out job done Quote
littlegreenmonster Posted May 20, 2014 Posted May 20, 2014 But if you look inside the light (take off outer casing carefully) it is only a bulb cap and i squeezed mine out of the hole (very carefully) so i have 98 spec lights and a reverse light hope that helps bud Quote
