Hey folks trying to fit tf035 to fe engine but there is not enough room for oil filter and sandwich plate for oil feed any help would be much appreciated.
Thanks, Chris
As above, you also need a new paper gasket for it and the big centre bolt, you will need the block tapped and threaded studs inserted to mount the housing.
i forgot i had fte oil housing haha i just found it in the garage will i need to take engine out to tap the block cause wont the metal shavings get inside, thanks alot guys its much appreciated.
