walshy992 Posted May 19, 2014 Posted May 19, 2014 im looking into buying a wastegate valve but were do u attach it and will it fit a ct9 turbo? Quote
JamesD89 Posted May 19, 2014 Posted May 19, 2014 You will have to have a manifold to suit mate and yes you can run one with standard turbo. James Quote
walshy992 Posted May 20, 2014 Author Posted May 20, 2014 cheers pal do u know where I could get a manifold from? Quote
5e colin Posted May 20, 2014 Posted May 20, 2014 you can weld on a pipe and flange on the 1 you have now ( aftermarket ) probly costs 50 to get done Quote
walshy992 Posted May 20, 2014 Author Posted May 20, 2014 can u weld it to the down pipe as ive not much room near my manifold? Quote
JamesD89 Posted May 20, 2014 Posted May 20, 2014 What mani do you have now? a good welder should be able to put a bend in to clear the standard rad if that's the issue. Any of the companies on here should be able to do this if your buying new. James Quote
walshy992 Posted May 21, 2014 Author Posted May 21, 2014 I got a cheap on but ive found a mani I have to order that is made to hold the wastegate. that was my plan to just weld a piece on but I got told it will just crack as soon as I boot it Quote
