Hey guys
Who has successfully done a led/smd conversion on there mk2 GT?
The dash bulbs are very dim and I will be fitting nice bright gauges so would be cool to freshen up the the old tired bulbs.
I either want white or green
Are the bulbs green or is there filters in the units?
Could someone also give me the bulbs sizes please and how many in each bit?
Thanks
Pics would be nice also!
Thanks guys
  • 1 month later...
Bump!
Posted Image
As you can see my bulbs are crap
can anyone confirm there t5?
how many do i need?
also
are the bulbs green or white std?
i wish to keep it oem green but just renew them with leds for better night time visabitly
Also what bulbs in the center console?
Thanks
Just get new bulbs. There capless bulbs that pop into the holder. Same bulb as for the parking lights.
Pop it out of the green holder and remove the green rubber piece from over it. Refit as you removed.
Here is mine. Very easy to do and very rewarding
D641E52C-23D6-4F0D-8AD8-C3650B31EF60_zps
I sooooo need these also. Foggy, do you have to remove the clocks and speedo cable to replace these bulbs?
Edited by Djaniero
I sooooo need these also. Foggy, do you have to remove the clocks and speedo cable to fit these bulbs?
No real need to get leds. I tried some in mine and it made the dash look cheap.
Yep pop out the clocks and disconnect the speedo cable. Very easy to do.
Easily change the lot in 30 mins. Id say i could prob do it now in less than 10mins
Well i seen how some leds make it look crap due to poor light spready hense looking at the frosted ones
Really tempted by them bulbs because they look standard and give good spread
Speedo cable easy to pop out?
Posted Image
Foggy is it only the 3 capless bulbs needed?
Removed my speedo before not to bad infact just need to find bulbs to fit the requirement
Bet i can find something better than standard
  • 3 weeks later...
Well I bought some single led white bulbs that are the same shape and size as oem bulbs.
Will put on the green cover and see how they come up tonight
I didnt just buy cheap rubbish so hopefully no damage to the speedo as I have heard it can.
Posted Image
Bulbs in and work
Used the green sleave but showing up blue kinda colour
Will see what they like later on
Might have to order green bulbs I think just worried about the light spread without the covers on the bulb
Yeah the needles are light up by the leds behind
Some good super bright red smds should make the needles go red.
One thing I need to figure out is you cant see from 7k to 9k
But thats a job for another day
Looks mega cool man.....so led bulbs work then and wont damage anything on the the circuit board?
Also after replacing my bulbs ive got a similar problem...from 0 mph to 60 mph...the dail is dim.....how did you manage to resslove that?
Thats the far left bulb mate
Theres 3 t10s and 1 t5
No damage to circuit board yet touch wood hopefully never either I paid a little extra for bulbs with warrenty just to play it safe.
Posted Image
I used the green bulb there its got plenty of light spread
wonder if there be any demand for me to make up some kits and sell them on here
