Hi guys,
Can anyone tell me the relevant torque settings needed? I've removed a piston for Suspect crack, so I'll need:
Conrod end cap bolt torques
Head bolts
Cam carriers
Cam pulley
And Any others would help
the head bolts: 22nm 44nm then 90 degrees
cam carriers: 13nm
cam sprocket/gear: 51nm
crank pully: 155nm
rocker cover: 7nm
inlet manifold: 19nm
exhaust manifold:48nm
spark plug:18nm
sump drain bolt:25nm
main bearings: 29nm then 58nm
big end bearings: 20nm then 40 nm
there's a few that will hopefully get you sorted if you need anymore torque specs give me a shout.
kevin
Wicked thanks mate, it's got a cracked. Piston so won't be going back just yet anyway, any idea how Much basic forge pistons and rods are? Lol
for the stage 1 kit you get:
wossner forged pistons
scat forged rods
acl main and big end bearings
Athena mls head gasket 1.2 or 1.4mm
ARP head bolts
price is £1.199
that's with tuning development, but if you keep a look out on the for sale section theres always forged pistons and conrod coming up for sale.
kevin
it would be good to have a pinned thread with torque settings for a lot of other things, I try to torque everything, but never know the right nM to use :/
