I'm in no hurry for any parts but just seeing what's available atm.
What I need is:
Gt thermostat housing with sensors nut/bolts etc
Oil cap (oem if poss)
Oem Crank pulley with no cracks or chips.
Looking to forge the engine as well so if any one has some new forged parts there wanting to sell let me know.
Cheers
I'm half way through taking the head off I've had problems finding all my tools as my shed sort of looks like your garage did lol. I'll be doing some more to it in a bit tho, the head will be off tonight so I'll get some pics up.
I've an oem oil cap im sure?! Ill have a look when im next at the garage for ya dude.
Cheers matey :)
Just got the head off any way and it's safe to say it has been a bit damp in there
56931176-B738-415A-BEBC-A429C0727BC2_zps
479A8DDC-2E5A-4301-A2FA-B9F94CDA6B31_zps
And on the exhaust cam I found this under #4 cap. The rest are ok but I'm not to sure what to do about this.
A2262951-483C-42A4-8272-2E50032B84B7_zps
B8B463D8-9756-4617-967D-AF24DC283FB6_zps
The bores are a bit crusty but they should be ok. I haven't got that far yet. I'll start on the bottom end tonight and get some more pics up.
Other then the cam the rest of the head is pretty good tho
She will be fine lol after a rebore , number three piston got a crack at all?
Number 1 piston was fucked along with the bore lol, I might get away with 75mm pistons in there but I'm not holding out much hope. I'll let the machine shop be the judge on that.
The crank needs a regrind really as it's pretty heavily scored but I wouldn't say it's fucked.
Still not sure what to do about the cam tho?
Any way, piston:
AC0C3B3C-299C-4252-AEAA-F15F587DF86D_zps
A couple of Bottom bearings (there all pretty much the same but you get the idea ha):
BA1E569B-E7A2-40C2-A957-44AD34C8209C_zps
Oh yeah it's pretty shagged. Was a right basterd to get out to. I'll pop it all down the machine shop when I get 5 mins and see what the think
I've got a couple more bits to add.
Need one of these as it was seized on the crank and I had to beat it off.
EE78679F-DE98-42C5-A5B7-2C2FCF3730E4_zps
EE7039BE-4AF3-4F14-9409-5484C8DC2802_zps
Also need the bolt that holds the crank pulley on however the threads inside the crank look rusted out does any one know if a larger bolt can be used instead?
I've cracked a deal on all the above parts apart from the thermostat housing and sensors, it must be complete tho
