dbrunton Posted May 30, 2014 Share Posted May 30, 2014 I had my discs and pads changed all round, when the front passenger side wheel was removed the bearing was loose so had the bearing tightened up. When I got the car back all was fine but after about 25 mile started getting an intermittent knocking noise coming from the front passenger side, it is more noticeable when the car is steering right. I took it to the garage today the car was put on the ramps there is no play in the bearings, bushed and everything else all seams tight and as it should so left the garage and typical for me as I was near home it started happening but it is coming and going. Anyone had a similar issue or any idea what this maybe. Quote Link to post Share on other sites
DavidAshton Posted May 30, 2014 Share Posted May 30, 2014 CV Joint. Did mine a few months ago after 2 years of it knocking on and off. Quote Link to post Share on other sites
H_D Posted May 30, 2014 Share Posted May 30, 2014 could be a worn cv joint. Quote Link to post Share on other sites
dbrunton Posted May 30, 2014 Author Share Posted May 30, 2014 cheers thats what a was thinking myself but it never happened till the brakes were done so wasn't too sure al get that checked. a know when it knocks you can sort of feel it through the steering wheel. Quote Link to post Share on other sites
H_D Posted May 30, 2014 Share Posted May 30, 2014 if it only happens when you are turning then its definitely your cv joint Quote Link to post Share on other sites
dbrunton Posted May 30, 2014 Author Share Posted May 30, 2014 cheers al get that looked at next week as there not that expensive. Quote Link to post Share on other sites
DavidAshton Posted May 30, 2014 Share Posted May 30, 2014 Just be careful you get the right one. The spline count is totally random and you need to make sure you get on with an ABS ring if you still have ABS. Quote Link to post Share on other sites
dbrunton Posted May 30, 2014 Author Share Posted May 30, 2014 mine still has abs was just looking on id-workz they have the one I need gonna get it looked at next week then get it ordered I think Quote Link to post Share on other sites
