Starletsr98 Posted May 30, 2014 Posted May 30, 2014 I have a 98 starlet sr and I'm fitting a gt turbo radiator, how do you bleed the system one it's been fitted, I can't find any bleed nipples, any help will be much appreciated as I have to do it tomorrow morning Quote
Jamie5414 Posted May 30, 2014 Posted May 30, 2014 Cap off, engine on, heaters on full hot (should see bubbling every so often) squeeze top and bottom hoses if you think there's still air in the system, should do the trick Quote
RobSR Posted May 30, 2014 Posted May 30, 2014 Like said, leave the cap of until the water is about to come out the cap, then nip it up. Quote
