scottieboi94 Posted June 3, 2014 Author Posted June 3, 2014 For that split second when you start without priming the turbo has no oil in it so that second starves it off oil. Like a new engine has oil in it but not all around so you prime it. Fair enough mate thanks for the help At least i know now for the future, ive removed the king lead for when i put the new turbo on so i it stops me from starting it and reminds me lol Quote
aidanep71 Posted June 3, 2014 Posted June 3, 2014 I'd just loop the water lines and take it for a run see what happens Quote
scottieboi94 Posted June 3, 2014 Author Posted June 3, 2014 the turbos off now mate i'm afraid so i'm just gonna see how it goes tomorrow with the old turbo on and if its still smoking then ill go from there. Regardless of whether it smokes or not, i'm going to get a compression test done tomorrow anyway. Quote
scottieboi94 Posted June 4, 2014 Author Posted June 4, 2014 I've done a compression and it running spot on with all cylinders and there is no white smoke from the exhaust with the old turbo on Quote
scottieboi94 Posted June 6, 2014 Author Posted June 6, 2014 Sounds like the turbos at fault then mate!' Yep you were right! ill be sending it off to you in the next few days pal Quote
Liam_D Posted June 6, 2014 Posted June 6, 2014 No worries at all mate! I can get our courier to collect it if you're struggling. Quote
scottieboi94 Posted June 8, 2014 Author Posted June 8, 2014 No worries at all mate! I can get our courier to collect it if you're struggling.If you could sort a courier out that would be brill mate, how much will it cost me to send it off? Quote
Liam_D Posted June 9, 2014 Posted June 9, 2014 Yeah we include courier services with our rebuilds buddy. Aslong as we repair your turbo it'll be free. Think you'll be talking about £25ish if you post it yourself all depends on weight. Quote
scottieboi94 Posted June 9, 2014 Author Posted June 9, 2014 Yeah we include courier services with our rebuilds buddy. Aslong as we repair your turbo it'll be free. Think you'll be talking about £25ish if you post it yourself all depends on weight. Ok brill mate, it'll just be the turbo and exhaust housing that will be in the parcel unless you need anything else? Quote
Liam_D Posted June 10, 2014 Posted June 10, 2014 Just the full turbo mate, actuator too so we can bolt that back on properly with the correct housing unless you're externally gated obviously. Quote
scottieboi94 Posted June 11, 2014 Author Posted June 11, 2014 Just the full turbo mate, actuator too so we can bolt that back on properly with the correct housing unless you're externally gated obviously. ok mate ill pm you on facebook to sort delivery out etc Quote
