scottieboi94 Posted June 1, 2014 Share Posted June 1, 2014 I think my headgasket is possibly on its way out, how easy would it be for me to replace this by myself? Quote Link to post Share on other sites
GlanzaJ Posted June 1, 2014 Share Posted June 1, 2014 Have you changed the turbo mate ? Quote Link to post Share on other sites
scottieboi94 Posted June 2, 2014 Author Share Posted June 2, 2014 Will be changing it this week, if the smoke goes away then I know it was the turbo but if it doesn't then head gasket I reckon Quote Link to post Share on other sites
H_D Posted June 2, 2014 Share Posted June 2, 2014 is it loosing any oil or water?Have you done a compression or sniff test, Quote Link to post Share on other sites
scottieboi94 Posted June 2, 2014 Author Share Posted June 2, 2014 Don't think its losing either, but its hard to tell, it may only be losing a slight bit mate Quote Link to post Share on other sites
H_D Posted June 2, 2014 Share Posted June 2, 2014 best thing to do is a compression test and sniff test before taking it apart.both tests should conform head gasket failure. Quote Link to post Share on other sites
scottieboi94 Posted June 2, 2014 Author Share Posted June 2, 2014 Getting the k1 rebuilt anyway just so I know its done then mate Quote Link to post Share on other sites
Ryan_EP82 GT Posted June 2, 2014 Share Posted June 2, 2014 Get a sniff test at any local garage as H_D says, then youll know straight away Quote Link to post Share on other sites
scottieboi94 Posted June 2, 2014 Author Share Posted June 2, 2014 Get a sniff test at any local garage as H_D says, then youll know straight away will do mate Quote Link to post Share on other sites
