strange wanted ad but here goes..
basically have the 4efe uk 98 n/a and have the full 5ef-he engine loom and ecu
wiring side of it i dont have a clue so need someone clued up with starlets to do the job.
car is in manchester
rather spend a little now then pay alot later and fry my ecu lol
  • 2 weeks later...
i think you should compare both loom alongside each other to see similiarities & differences,use both looms to make one,& i know its easier said than done
Theres not that many wires that need wiring in.
Starter signal and power
Fuel pump
Oil pressure switch.
Rev's
The engine loom along with the ecu can all be put in place. The there's some obvious ones into the bay fuse box that you can do yourself.
Some others but it's just trial and error with a multimeter and labelling what you need and where they go. Plugs can be re pinned to keep it neat the rest you can do with chocolate blocks to test until it works then once you're happy solder it up.
Just have a few spare fuses as it doesn't always work so need to fire some new ones in until you figure it out
