Mild steel for external wastegate welding
The manifold i have the external wastegate runner has been modified in a clever way in which it causes the wastegate to smack on the radiator. I have a welder lined up to sort it out but need to source some bends etc to reposition the wastegate. Anyone point me in the right direction
hi lad I have a mild steel 90o elbow sch 40 3.6mm thick, inside diameter 35mm, outside diameter 42mm its good quality steel and I made my ramhorn manifold from it.
you can have it if its any good to you as long as you pay for postage.
kevin
