kbond Posted June 7, 2014 Share Posted June 7, 2014 Need all you experts to help me here as I've just about had enough of this carI'm getting rumbling feeling (as if your driving over rumble strips) as I'm driving along, it does not change if your going flat out or foot on the brake, it just gets faster with speed.I have changed all ball joints, bushes, cv joints, fitted coilovers (which just made you feel it more) and it's made no difference!I'm trying not to spend on the car at the moment as me and the misses are looking at moving but this is my daily so need it fixed or she's going! Help please!!!!!!!!! Quote Link to post Share on other sites
rinseep82 Posted June 7, 2014 Share Posted June 7, 2014 Not changed wheel bearings then ?? Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 There is no play in the wheels at all, if you spin them they are quiet, and even go through all gears when up in the air it's silent no movement or noises Quote Link to post Share on other sites
daniel_g Posted June 7, 2014 Share Posted June 7, 2014 Are your wheels balanced and tyres in good condition, ie no flat spots or ovals ? Could try swapping the wheels front to back. Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 Done all of that Quote Link to post Share on other sites
rinseep82 Posted June 7, 2014 Share Posted June 7, 2014 Both tyres on the front the same brand ?? Quote Link to post Share on other sites
daniel_g Posted June 7, 2014 Share Posted June 7, 2014 Are your driveshaft balancers there and in good condition ? Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 Toyo t1r on frontGoodyear eagle f1 on rearNo flat spots all balanced twice Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 Are your driveshaft balancers there and in good condition ?Have you got a pic to explain what you mean? Quote Link to post Share on other sites
daniel_g Posted June 7, 2014 Share Posted June 7, 2014 If you look in this thread you'll see the longer driveshaft has a rubber ring looking type thing wrapped around it, balancer, sometimes the rubber can perish and come loose making the driveshaft unbalanced causing a vibration. http://www.google.co.uk/url?q=http://www.toyotagtturbo.com/forums/showthread.php%3F68615-xs-power-radiator-Gt-quad-grill-fuel-rail-adapter-and-spares-for-sale&sa=U&ei=XWGTU-qMAYfBOM_4gPAL&ved=0CCYQ9QEwAQ&usg=AFQjCNGzKS6TkyERWPdWCrmx5K-8jnOYuQ Is quite unlikely though. Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 I have an LSD box so I have two smaller shafts should they still have them? Quote Link to post Share on other sites
daniel_g Posted June 7, 2014 Share Posted June 7, 2014 Not sure, worth a check atleast. Quote Link to post Share on other sites
kbond Posted June 7, 2014 Author Share Posted June 7, 2014 I haven't got them on my shafts...... Quote Link to post Share on other sites
