Rob Scott Posted June 10, 2014 Posted June 10, 2014 Hi all, Will a FWD corolla, or MR2 4AGE bellhousing fit onto a starlet/Glanza box?Cheers Quote
richardc9052 Posted June 10, 2014 Posted June 10, 2014 Yes they will. Depending on the bearings you may need to change them too but a turbo bell housing into a 4age box should match up Quote
Rob Scott Posted June 10, 2014 Author Posted June 10, 2014 The thing is,I have a starlet box with LSD, I want to keep the box, and fit a 4AGE engine. Quote
morgey Posted June 10, 2014 Posted June 10, 2014 A 4age box has the same 8 bolt diff as a starlet turbo so the diff itself is interchangeable. Or as mentioned before. Just swap the bell housings Unless you have an oem lsd box then I doubt he bell housings or the diffs are interchangeable. Quote
richardc9052 Posted June 10, 2014 Posted June 10, 2014 The thing is,I have a starlet box with LSD, I want to keep the box, and fit a 4AGE engine.Yeah bud it works both ways Quote
Rob Scott Posted June 10, 2014 Author Posted June 10, 2014 its a Cusco LSD. Cheers for that, Rallycross this weekend, i was defo short of power with the 5E, so i think a 4A-GE is nextjust couldnt keep up with the beams engine'd MR2 on the straights Quote
richardc9052 Posted June 10, 2014 Posted June 10, 2014 Sounds like a plan! You will need to notch the drivers chassis leg unless you move the whole plant position but then you have to change drive lengths etc Quote
Rob Scott Posted June 10, 2014 Author Posted June 10, 2014 yeah i was planning on keeping the box in the same position, just cutting away the chassis leg.No point in making custom driveshafts, as i need easy to find spares.Ive gotta keep 1600cc, anyone ever fitted a 20v into a RHD? or is the master cylinder in the way? Quote
richardc9052 Posted June 10, 2014 Posted June 10, 2014 They should be the same.. I'm sure there is a 20v starlet on here.. Might be morgey above.. Should be same as a paseo? Quote
Rob Scott Posted June 10, 2014 Author Posted June 10, 2014 i've got a feeling the throttle bodies on the 20v will be in the way of the master cylinder Quote
