GlanzaJ Posted June 10, 2014 Share Posted June 10, 2014 Recently bought a full wepr td04 kit , the problem i have is that i have a half size rad and the lambda that comes off the down pipe sit's literally on the rad hose ! , i find out the hard way when i was going down to north weld air strip and it split the hose ! Quote Link to post Share on other sites
wickedep Posted June 11, 2014 Share Posted June 11, 2014 hi mate, if your civic rad has the bottom radiator port on the drivers side..then it will foul. you need to find a civic radiator with the bottom port on the passenger side (like stock radiator) or have your bottom port shifted to the other side. hope this helps !! Quote Link to post Share on other sites
