with the right parts fitted to compliment the ecu you will see some good gains
5efhe camshafts
4-2-1 exhaust manifold (obx make one)
lightened flywheel
the six speed box ratios also compliment the na engines quite nicely.
a nice airbox system bmc cda for example.
also remove any unessercary weight.
also see if you can get a acis manifold and 5efhe ecu then remap that ecu with a piggy back
Edited by vulvachops
you knead a stand alone on the 4efe and a fully ported head with high lift cams and 8000 to 8500rpm to get any decant gains !!!! and the extras mentioned above
also bottom end nead a total rebalance
